Rear lamps only work when braking
Old Jan 31, 2018 | 05:36 PM
Josh Coker's Avatar
I just got my car back from a mechanic and he was not able to solve this issue. I have changed the fuse and bulbs on a more frequent basis. Now the lights only work when the brake is pressed. Thoughts?
Old Jan 31, 2018 | 06:06 PM
The brake light is only supposed to work when the pedal is depressed. Do the tail lights work, do the turn signals work?
There are 2 elements in the bulb. One is for the stop/turn one is for taillights. In case you are unaware, the tail lights do not turn on when in the DRL mode are on only when the headlights are.
Fuses don't just blow, there is a reason.
junker
11
Jun 9, 2016 06:36 PM
Jeffharden1
Aug 25, 2014 01:50 PM
06chevyHHR
Jul 1, 2013 07:07 PM
terryk
Feb 18, 2010 12:05 AM
