rear tail lights
Old Jun 27, 2014 | 11:25 PM
LEN's Avatar
LEN
rear tail lights
how do you get at the rear tail lite bulbs to change them. thanks in advance.
Old Jun 27, 2014 | 11:53 PM
blizzard's Avatar
open up the rear hatch. on either side you'll see an almost oval access panel. pry it open , reach in and you can get at the bulb from behind
Old Jun 27, 2014 | 11:54 PM
Moved from the How-to section to the problem section.
Details on changing them is detailed in your owners manual. If you do not have a copy you can download a copy from here (use the search tool to find the links).
But basically they are replaced via the little rectangular doors inside the rear of the vehicle on either side of the hatch opening.
datekman
Apr 11, 2024 08:31 AM
JRGHHRSS08
Aug 16, 2010 08:21 PM
