Rear windshield washer fluid is leaking.
We had abnormally low temperatures the week before last. (Down to 8 degrees). Today I turned on the rear wipers and washer, but no fluid came out. I checked the back of the vehicle and saw fluid on the sides of the interior. How do I repair this?
Take the top stoplight cover you'll see the tube that has broken. Hopefully just a splice will fix yours as it did on mine.
If you are unlucky, you will need to remove the headliner and either find the spot or replace the entire tube. Not impossible to do, but a PIA.
Welcome to the site
Here is a thread about fixing that problem
https://www.chevyhhr.net/forums/problems-service-repairs-42/rear-window-washer-leak-39307/
