Rear Wiper Fluid not Working
Old Mar 3, 2021 | 07:34 PM
Ronnie's Avatar
Can anyone shed some light on why my rear window fluid isn't pumping fluid. But my wiper is working.
Old Mar 3, 2021 | 07:47 PM
Look at the hose under the hood at the base of the washer fluid tank for leaks, then look at the lift gate hinge area for leaks.
Old Mar 3, 2021 | 11:48 PM
Ronnie's Avatar
I will have a look under the hood in the morning after work. I haven't seen any leaking in the lift gate area. I took the HHR to the carwash again to clean out the door hinge areas and under the hood. And vacuumed the rear area and under the back seats...it was full of straw. And the other areas looked liked it had been stored under a tree...a
bunch of crumpled leaves and small tree particles.
Old Mar 4, 2021 | 08:04 AM
Do you use -40 washer fluid or plain water? Plain water will freeze and burst pipes and motor seals.
Old Mar 4, 2021 | 09:32 AM
Ronnie's Avatar
I didn't see any leaks
Old Mar 4, 2021 | 09:35 AM
Ronnie's Avatar
I use actual windshield wiper fluid. Though I recently purchased this HHR...I would believe they used windshield wiper fluid too as there was a bottle left in the car.
Old Mar 4, 2021 | 09:36 AM
Now comes the fun part, if the temperature outside is warmer, I think you said 60 degrees F , try the rear washer again, perhaps it was frozen
Old Mar 4, 2021 | 11:28 AM
Ronnie's Avatar
It's pushing 70 now and still not pumping fluid. 😞
Old Mar 4, 2021 | 01:17 PM
Then on to removing the rear panel to see if the hose or tube slipped off the squirted nozzle.
#8&9
It’s routed up there
Old Mar 4, 2021 | 05:18 PM
Ronnie's Avatar
#8&9
Ugh...I am.tired of taking stuff apart. 😭 But I will another day. Thanks for the info!
