Reduced engine power
Old Sep 25, 2022 | 02:53 PM
  #61
Jasonw7684's Avatar
When I put an ECM in, also VIN programmed, I had to perform the key relearn procedure.
1. Depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
2. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
3. Turn the key off for 5 seconds, then depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
4. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
5. Turn the key off for 5 seconds, then depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
6. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
7. Turn the key off for 5 seconds, then depress the clutch and try to start the car. The car should start on this attempt.
Of course, this is for manual transmission, not sure what the differences are, if any, for automatic.
The formula of trying to start, leave key on for 10 minutes, then off for 5 seconds, repeated, should work.
It's automatic but yes I did the procedure as they recommended from the place i bought the ecm but other than when I first turned key on the theft light was never on nor did it ever come on during process.
Old Sep 25, 2022 | 02:55 PM
  #62
Jasonw7684's Avatar
Originally Posted by donbrew
Now that I know the trans was replaced, I think you should try cranking down on the bolts that hold the underhood fuse box together, they need to be tightened way more than "as tight as I can before they strip" you need to hear a few clicks.
When i replaced the box i tightened it till it clicked, i read about this issue on other threads.
Old Sep 25, 2022 | 06:08 PM
  #63
greg8453's Avatar
All of them?
Old Sep 25, 2022 | 07:03 PM
  #64
Somebody recently corrected me for saying "until it clicks", they said it took 3-4 clicks. Every one of the fuses and relays need to click into the sockets.
Old Oct 1, 2022 | 11:48 AM
  #65
Jasonw7684's Avatar
Well finally got it going, loose connection in fuse box. Now I am getting code p0315 and p0480.
Old Oct 1, 2022 | 12:06 PM
  #66
https://www.obd-codes.com/p0315
https://www.obd-codes.com/p0480
Old Oct 1, 2022 | 12:12 PM
  #67
Jasonw7684's Avatar
the first link isn't working and I got the p0480 one fixed by replacing relay.
When the car is running it idles normal and seemed to drive normal when I took it around the block before checking codes.
Old Oct 1, 2022 | 12:17 PM
  #68
Here’s that link , it opened for me
Old Oct 1, 2022 | 12:29 PM
  #69
I'm not sure what happened. I had a heck of a time getting the second link to insert, now the first link has the same target as the second!
Old Oct 1, 2022 | 01:05 PM
  #70
Jasonw7684's Avatar
lol it's ok I went and found it on that sight. Thanks
