remote door lock problem
Old Jan 10, 2016 | 03:27 PM
mister hhr's Avatar
2011 hhr drivers door wont unlock with the remote all other doors work fine have to use the key to unlock the door the lock knob goes up and down but it wont unlock the door without the key even after driving the car when you put it in park the lock wont work you have to pull the knob up to unlock the door all other doors unlock as normal.
Old Jan 10, 2016 | 04:08 PM
Try lubricating the lock or your actuator is burnt out
Old Jan 10, 2016 | 06:21 PM
The actuator is integral to the latch ($$$$). You might be able to install a generic actuator. Like this: 2 Set Car Truck High Quality Universal Power Door Lock Actuator Motor 12 V | eBay
I did that on my Mazda, just hooked it up to the mechanism and wired it into the existing wires,
Old Jan 10, 2016 | 06:54 PM
mister hhr - Looks like you will have to pull the door panel to check out the innards - here is a link to some info that might help if you do it yourself: https://www.chevyhhr.net/forums/how-...removal-14040/
asanti
Jul 8, 2016 04:54 PM
dmfost
Mar 15, 2015 04:31 PM
rash4843
Nov 11, 2013 12:08 AM
Jace1283
Dec 8, 2009 06:13 AM
BlackHHR06
Sep 7, 2007 08:17 PM
