remote door opener
Old Oct 4, 2012 | 09:25 AM
dodger542000's Avatar
remote door opener
Hi. Have a 2008 LS. Remote door opener is malfunctioning. It used to start the car as well as open and lock it. Now it just opens the doors. Is there any way it can be fixed ar replaced? How much would it cost?
dodger
Old Oct 4, 2012 | 09:59 AM
gerrbear's Avatar
who made the remote? if it was python....go to they're site.or google the name on your remote
Old Oct 4, 2012 | 03:05 PM
Sno White's Avatar
Suggest you start here:
https://www.chevyhhr.net/forums/how-tutorial-library-21/repair-key-fob-remotes-worn-out-contacts-30813/
If it is a Remote or FOB problem.
If it is a Remote Starting the engine problem there are other threads detailing just all the conditions that must be met before "Remote Start" can be done. First is the Check Engine Light on - if so, no go. Conditions can be found in the owner’s manual as well.
Old Oct 4, 2012 | 08:56 PM
alexrckid's Avatar
www.keylessfix.com
Old Oct 4, 2012 | 08:57 PM
alexrckid's Avatar
check out the keylessfix help section
Old Nov 26, 2013 | 03:26 PM
wendykay's Avatar
Originally Posted by alexrckid
A new one at ebay.com is more economical, and less trouble!
Old Nov 26, 2013 | 04:06 PM
Just to clarify:
If you are meaning a totally new remote, complete with case, keypad, and circuit board, you are totally wrong.
A new remote like that has to be sync'd/programmed to the car - and most dealers charge $30-$80 for that as it involves reprogramming the car. A new remote cannot be programmed by an owner to the car like a lot of remotes. The car has to be programmed to the remote, and that is not a task that the owner can do.
Keylessfix has replacement keypads that work well to replace those with worn out contacts, and they apparently stand behind their product - whereas a number of the replacement pads from ebay can be a carp-shoot.
Old Nov 26, 2013 | 05:42 PM
Snoopy's Avatar
Agree with whopper, who almost always gives accurate advise
The keylessfix people, last I looked, charge $12.00 for the new pad. I bought one and it solved my problems. Easy repair also....takes about 10 minutes.
Old Nov 27, 2013 | 01:20 AM
[QUOTE=Snoopy;727018]Agree with whopper, who almost always gives accurate advise
QUOTE]
LOL - well I thought I was wrong ONCE!!! But it turns out I was only mistaken!!!!!!
and right back at ya Snoopy - you are always on top of things and your advice can be well counted on. Glad you are here man.
BlackHHR06
Sep 7, 2007 08:17 PM
Snoopy
Jul 3, 2007 01:27 PM
tleslie79072
21
Jul 2, 2007 04:44 PM
NHHHR
May 31, 2007 04:30 PM
