Remote won't respond, any last ideas?
Old Sep 4, 2012 | 01:57 PM
HWD510's Avatar
Question Remote won't respond, any last ideas?
My remote was working fine until I came out of a restaurant one day and it did not work anymore. I replaced the battery inside the remote and that did not help. I even went to my local Autozone and used their remote signal detector and all of my buttons are sending out a signal. So it sounds like my remote is working but my HHR is not responding back. What can I do on my own before I go back to the dealership? I really despise going to the dealership, I don't trust them from my previous experience.
Old Sep 4, 2012 | 02:40 PM
the_shmoo's Avatar
Try disconnecting the battery for 20-30 mins. to reset the BCM. Worked for me.
Hope this helps.
Old Sep 4, 2012 | 02:59 PM
HWD510's Avatar
Thanks, I will give this a try. Are there any side effects from doing this? In other words, will disconnecting my battery for 30 mins do harm to my HHR?
Old Sep 4, 2012 | 03:48 PM
swerv0428's Avatar
Nope won't hurt anything. Just have to reset your radio presets!
Old Sep 4, 2012 | 04:07 PM
HWD510's Avatar
No biggie then!
Old Sep 4, 2012 | 05:02 PM
the 30 minute battery fix worked for me last year, and I found half of my presets I don't use anymore, so maybe 2 birds with one stone for you!
Old Sep 4, 2012 | 05:26 PM
Gsus's Avatar
Check the fuses blocks maybe it can help.
fuse 26 Door Locks. it is inside at the passenger side.
Old Sep 9, 2012 | 08:44 PM
Mikeco613's Avatar
Mine doing the same thing
Mine just recently started to intermittently work. Got progressively worse. Now, it works sometimes but mostly not. Did change battery in remote. I hope this battery disconnect trick works, but I know my luck. Thanks for the tip.
Old Sep 9, 2012 | 09:23 PM
AngelJ's Avatar
keyfob problem
Found this on another thread -
keylessfix.com
Old Sep 10, 2012 | 01:01 PM
How did the disconnection of the battery do for you?
