Needing Assistance (DTC P0016)
Old 11-08-2014, 01:27 PM
Tinman52's Avatar
Post Needing Assistance (DTC P0016)
Have a 2009 HHR, 3 days ago it started running sluggish, wouldn't accelerate properly but had no problems starting. Check engine light came on, Code P10016 came up, I changed out both crankshaft and camshaft sensors and the engine light and same code are still coming on. Have no idea what could be the issue, any help would be greatly appreciated.
Tinman52 is offline
Old 11-08-2014, 02:24 PM
Welcome to the site.
There is no P10016 trouble code. Could you repost to verify. (assume you mean P0016, but need to make sure)
Also posting the engine size would help.
firemangeorge is offline
Old 11-08-2014, 02:57 PM
Technical Moderator
If it is P0016 why did you change the sensors? It does not indicate bad sensors, just that the sensors don't agree with each other. This is where the mileage comes into play, you may be lucky and only need a tensioner most likely you need a new timing chain and guides.
Here is a link: P0016 Crankshaft Camshaft Position Correlation DTC
donbrew is offline
kellytx4
07-14-2013 10:22 AM
GberrySr
10-03-2012 11:48 AM
Archbold
02-05-2012 10:12 AM
uglyjim
12-07-2010 09:56 PM
BigBear45
18
01-15-2010 01:44 PM
Quick Reply: Needing Assistance (DTC P0016)
