Replaced Timing chain tensioner - now big problem
Old Sep 16, 2016 | 09:29 PM
I guess you confused him, too.
Let's not make whopper change his oil again, please.
Old Sep 17, 2016 | 08:17 AM
Jimmy68's Avatar
Originally Posted by Jim Wells
2006 2.2L HHR, I noticed a rattle every time I started the engine, I replaced the timing chain tensioner to the new style as recommended, the old one came out in pieces but nothing fell down inside, I primed the new one and installed it, I then turned the engine over and it rattled and spun, I am wondering if the chain either slipped off or broke, now the engine just spins and seems to have no compression holding it back, am I screwed?
Jim, my 08 2.2L was doing this and a month ago I swapped tensioner.
Same thing as yours. So I bought a New (used) engine and had that installed.
Old engine is junk. Good core.
Not saying your is but sounds the same. You bent your valves. Was cheaper to just swap engines with a low miler.
Old Sep 17, 2016 | 11:30 AM
Without the VVT
Old Sep 17, 2016 | 11:32 AM
With VVT note the Black exhaust solenoid and the grey intake solenoid
hurst2001
May 17, 2020 01:55 PM
prod
"How To" Tutorial Library
164
Jul 12, 2018 08:20 PM
only1hhr
Nov 8, 2014 04:50 PM
Lucky
Apr 25, 2014 05:31 PM
Junior864
Oct 12, 2012 02:39 PM
