Replacement engine
Old Sep 23, 2019 | 09:38 AM
Boonedox's Avatar
Replacement engine
2010 with bad 2.2 engine,,do I need too stay with a 2.2,, or can I use a 2.4 in its place and if so what would I have to change to get it to hook up?
Old Sep 23, 2019 | 11:02 AM
Cat Man HHR's Avatar
Keep it simple.
Stay with what you have.
Less problems.
What year is yours ?
Old Sep 23, 2019 | 11:37 AM
They will interchange physically, 2009 and up 2.2’s have VVT as do the 2.4 .
Sensors may need to be changed for the new 2.4.
I suggest you do some investigating and compare part numbers .
The throttle body might have a different connection.
The ECM might be programmed differently.
hellshotrod can answer those questions. David has handled this swap before.
Old Sep 23, 2019 | 01:35 PM
Boonedox's Avatar
2010 lt
weisside
Sep 12, 2017 11:35 AM
Nat
22
Oct 16, 2014 09:10 PM
roofer1976
Jan 20, 2012 01:49 PM
menance
Dec 22, 2010 06:14 PM
plumb34
Jun 15, 2010 05:14 PM
