Replacing the thermostat tomorrow, how annoying is it to locate and access?
I see a couple videos showing the process, but they'e all already IN the engine. I can't find any videos, pics, or diagrams of how and where it actually is located.
Here is the How-to article on replacing it - it's pretty straight forward, but it is a rather tight place to work in - https://www.chevyhhr.net/forums/how-...l-p0128-24493/
Just be sure to pay the extra $'s and get the right thermostat -
Thermostat - (2006-2011 All Models) ACDelco 131-158 GM P/N 12622410
https://shop.advanceautoparts.com/p/carquest-thermostat-48628/10006717-P?searchTerm=Thermostat
I can't imagine why it wouldn't work :/
Do a search here and read a few of the hundred or so posts to enlighten your imaginatiion.
Basic info:
the rubber gasket on the valve part is what fails, the correct part has metal to metal sealing
the temp response may not satisfy the computer
Basic info:
I’ll see you back here in a few months , when the P0128 pops up again, the aftermarket thermostat’s won’t operate within the parameters the computer is looking for, I’ve tried Stant, Motorad and Gates, all failed within a month or two. I installed an AC Delco 131-158. It’s still working 5 years later.
