Rotors ( Funny Sound)
Old Jun 25, 2007 | 09:25 PM
gtpman29's Avatar
Originally Posted by Snoopy
along with the torqueing spec's and tightening the lugs in the "star" pattern, make sure you clean the mating surfaces of the hub and rim very well....use a wire brush on rust and dissimilar metal corrosion.....as per GM's TSB. Also, either remove or be extra careful with the retaining clips found on the hubs. They have been know to cause problems such as you discribe.
should i still used the old retaining clips or get new ones or not even use them ? thank for the help neal
GinaM
May 25, 2014 09:50 AM
Jeff®
Jun 4, 2011 03:51 PM
voigtsga
12
Oct 7, 2010 01:17 AM
esmarkey
Jan 29, 2009 04:15 PM
upOnGamE
Nov 10, 2006 11:14 AM
