Same issue different problem
This is related to the blower motor issue somehow.What happens when you remove or check a fuse or relay to make a key not work and how is it fixed? Does the key need to be taken to a dealer to be reset or can it be fixed by the owner somehow.I'm used to dealing with old school technology(pre-computers and electronics)so any help is appreciated so I don't have to take it to a dealer.Sorry to sound ignorant but this is pissing me off !!!
I got the key issue resolved this morning. Just had to insert the "working key" in and turn on the engine. "Then turn the engine off and within 5 seconds put in the "non-working" key and turn to "run" but don't start the engine. After 5 seconds the key should be reprogrammed. Worked 1 st try !!! The info was listed under PASSKEY III in the owners manual. Now,back to the issue of no A/C. I did look at the cabin filter closer and it looks as if it's never been changed. At least not for quite awhile. It is stained like you said.
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
Black Rose
Dec 7, 2007 11:28 AM
