Scraping noise when braking
Old Dec 12, 2022 | 08:14 PM
CP_HHR's Avatar
The front brake pads look thin. Maybe it would be a good idea to have a mechanic look at it.
Old Dec 13, 2022 | 08:06 AM
It’s your money, but if you’re not comfortable doing it yourself, then ok.
Old Dec 13, 2022 | 09:49 PM
greg8453's Avatar
Do you have a wrench/socket set and basic knowledge of using them you can save a bit of money and you should have no problem doing it in an afternoon taking your time.
Old Dec 16, 2022 | 12:46 PM
CP_HHR's Avatar
They checked and cleaned the HHR brakes on the 14th and I brought it home after paying them $75. It rained yesterday, so I waited until today to look at it. I took the front wheels off and looked at the brake pads and there seems to be enough there for now. One pad looks like its getting thin. I can't turn the bolts on both sides. I even tried using a piece of pipe as an extension on the ratchet. I sprayed WD 40 on them and put the wheels back on. I was going to look at the rear brakes later. I took some pictures.
Old Dec 16, 2022 | 01:55 PM
Wd40 is not a penetrant. Get some PB Blaster, or Kroil if you can find it.
After spraying, give each bolt or nut a few taps, the vibrations help it work in.
Old Dec 16, 2022 | 02:21 PM
You remove the 14 mm head bolts from the caliper slides first to remove the caliper . If you are replacing the rotors, the remove the 15mm head bolts that you sprayed with WD40, those are torqued to 85 ft lbs, so maybe somebody used an impact gun on those!
Old Dec 16, 2022 | 06:15 PM
greg8453's Avatar
Look at the back side of the caliper to see how much pad is left.
Old Dec 17, 2022 | 07:38 AM
CP_HHR's Avatar
It lloks like I was trying to turn the wrong bolts. I looked at a Haynes repair manual and it shows the caliper being removed while the U-shaped doohicky stays on.
Old Dec 17, 2022 | 07:54 AM
greg8453's Avatar
The caliper uses two small bolts to secure it to the BRACKET which uses the larger bolts. You have to remove the bracket to replace the rotor.
Old Dec 17, 2022 | 10:33 AM
As I indicated in an earlier post!
