Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Those codes indicate you forgot to plug the MAF back in after the air filter change.
Why are you worrying about 204F in Houston stop and creep traffic? That sounds pretty normal. The temp is supposed to be ABOVE 180F and the fan doesn't come on until 219F unless the AC is on.
$100 labor for the t-stat is NOT a good buddy deal. Only 2 bolts and lose about a thimble full of coolant. Much more important to replace the over 5 year old Dexcool; it has a 5 year shelf life.
