Serpentine Belt Issues
Old May 15, 2019 | 09:23 PM
Eric Perryman's Avatar
So Yesterday my serpentine belt starting squealing anytime I would be at a stop and then go to give it gas. After a few seconds it would stop squealing. Was going to replace belt tomorrow but it busted while driving today so I replaced it today. After a brand new belt it is squealing again but ONLY when the AC is on. If the AC is completely off its 100 percent fine.
Old May 15, 2019 | 09:44 PM
I wonder if the AC is making the noise?
Old May 15, 2019 | 10:17 PM
I would have spun the tensioner pulley, then the A/C pulley to see if you can isolate the issue, cause that new belt may not last otherwise.
Something "sounds" to be stopping then you get the squeal.
Old May 16, 2019 | 06:48 AM
The tensioner and pulley should be replaced at the same time as the belt.
X2 on checking the other parts
Old May 16, 2019 | 05:47 PM
Blue_SS's Avatar
I'm with sleeper. Spin things with no belt installed. The culprit would seem to be your AC compressor, but make the rounds. The AC is also the biggest load applied to the belt, when it kicks in. There may be another issue that only arises under a load. Best wishes.
Old May 16, 2019 | 08:24 PM
I know on the wifes Mopar I just replaced the Alternator de-coupler pulley, & figured may as well replace the tensioner, both idler pulleys & belt while I had it apart.
It was actually cheaper to get the Gates* kit, than to buy just certain pieces from Rockauto.com. Car sounds like new again.. Thanks Rockauto.com & I got a discount for being a member here.
Old May 17, 2019 | 04:45 AM
geg's Avatar
geg
Here is my version:
the generator bearings are dead, the belt is turning the pulley with difficulty, slides on the surface of the pulley and whistles.
From the poor performance of the generator, the emergency light (picture "battery") on the dashboard turns on.
If it is a generator: Disassemble the generator, replace the bearings, simultaneously test the electric brushes and copper rings - this is probably worn out too. Even if the wear is not strong, it does not hurt to replace it anyway so as not to gut the generator twice.
Old May 17, 2019 | 05:28 PM
Silverfox's Avatar
What's the mileage ??
That might help reveal more credible ideas to consider.
Silverfox
hhrEH
Maintenance and Upkeep
68
May 26, 2025 04:22 PM
intofocuszx3
Apr 19, 2013 08:07 PM
Kliinski
Dec 16, 2011 08:54 PM
RICK167448
Jul 26, 2010 08:42 AM
RICANBABY
Jul 28, 2007 08:15 PM
