Service ESC Dashboard Alert Help Required!
Old Dec 10, 2023 | 08:53 AM
The ESC light alone only means the ESC is turned off, not that there is a specific problem.
ESC attempts to get the car stabilized by manipulating the brakes and the horse power/torque output of the engine by manipulating the valve timing and the accelerator pedal. It might also manipulate the transmission. No ESC on cars without VVT. Not the sane as Traction Control
You have to remember the car is really a computer network on wheels, even the brake lights are computer controlled/
How many times have you seen "there is ONLY 1 minor code"?
Try a GoOgle "how does electronic stability control work". Lots of stuff there.
Old Dec 13, 2023 | 02:46 PM
PulpFriction's Avatar
Originally Posted by donbrew
...ESC attempts to get the car stabilized by manipulating the brakes and the horse power/torque output of the engine by manipulating the valve timing and the accelerator pedal. It might also manipulate the transmission....
I'll try that. Both baffled and fascinated by the idea that valve timing would be used for stability control. Want to understand it.
I was always beyond skeptical when owners claimed that replacing VVT valves fixed an ESC problem, unless there was a VVT code. It does seem completely plausible that a VVT problem would hobble the engine, thus interfering with proper ESC operation.
Old Dec 13, 2023 | 02:59 PM
The other way around. The ESC uses the VVT to control the torque.
Gearhead1
Aug 30, 2023 11:45 AM
MagicSpoolBus08
Jul 26, 2021 09:11 PM
flstss
Nov 16, 2017 08:51 PM
cloudhome
Nov 4, 2016 07:50 AM
HHR 2.0
Maintenance and Upkeep
7
Oct 30, 2015 08:33 PM
