Service traction and service ecs message
Old May 8, 2014 | 08:20 AM
Cascious King's Avatar
2011 HHR LS Panel Ok. I spent the morning googling this. Looking to verify my findings
First , with just these two messages "service traction" and "service ecs". NO other warning, Autozine or any other chain cannot pull up any codes , correct? I'll have to got service to pinpoint the problem?
Second, the car idles great, I put it in drive and accelerate slow, it's ok, I hit the gas some and it goes but sputters and sounds weird. Seem to have power still though. Is this related to my messages?
Still googling but using my phone... Painstakingly!!!
Thanks
Old May 8, 2014 | 08:25 AM
Lucky's Avatar
Welcome to the site most auto parts stores can't read traction control fault codes. I would stop by and let them try anyway.
For some engine and trans codes the computer turns off the traction control
Old May 8, 2014 | 08:52 AM
bigwillyg's Avatar
It's been my experience that the traction control service warning is a red flag to force you to get the car checked out. It turned on right before my car's original engine threw a rod and it turned on when my spark plug threads were bad and the ignition cool was about to get blown out.It also turned on when my camshaft actuator solenoid stayed going bad. It's a harbinger of bad things to happen.
By all means, get it to the dealer and checked out immediately. Bad things will happen.
Old May 8, 2014 | 09:21 AM
I did replace the cam actuator after engine light came on just about a month ago. Only Intake side and code cleared though.
I'll have to stop by GM for diagnosis l guess . Hope it can be done without dropping car off! That way I know for sure
Old May 8, 2014 | 09:42 AM
bigwillyg's Avatar
Good to hear you got it taken care of. I'm paranoid about the traction light after my experiences.
Old May 8, 2014 | 01:15 PM
Silverfox's Avatar
Just a thought.
Check to see if your Traction Control switch is turned off.
That triggered the message for me after a while.
Silverfox
Old May 8, 2014 | 03:04 PM
new development on esc warning
Thanks
So just a bit ago a coworker tells me my brake lights are always on. He said he hadn't noticed it the past few days so it must be a new issue. I investigated a bit an narrowed the issue down to the brake light switch at the top of the pedal. looks like a piece broke off.
My question!!! Would this be my reason for getting the service traction and service esc warnings.....it seems to have both come about at the same time.
Either way, apparently they need to use a scan tool to calibrate the new switch so im going to GM no matter what.
Old May 8, 2014 | 03:42 PM
db/sb's Avatar
I don't recall needing a scan tool when I changed the switch on my niece's HHR but it does have to be adjusted properly.
Old May 8, 2014 | 05:39 PM
Originally Posted by cascious king
my question!!! Would this be my reason for getting the service traction and service esc warnings.....it seems to have both come about at the same time.
yes!
Old May 8, 2014 | 08:50 PM
Lucky's Avatar
Yep that would be your problem with your traction control. I don't think there is any calibration when installing the brake lamp switch just an adjustment that is nothing more than pulling up on the brake pedal to set it once it's installed.
pipilo
Sep 2, 2017 09:43 AM
mallomar
Oct 27, 2016 05:48 PM
dlmhhr
Dec 28, 2013 12:43 AM
Lake Runner
Dec 10, 2012 09:33 AM
Li'l Hearse
Apr 16, 2009 07:33 AM
