Sloshing noise
Old 11-09-2009, 07:33 PM
djr1973's Avatar
Sloshing noise
Has anyone experienced like a water sloshing noise that sounds like its in the dash after you first put it in gear and start to move?? I noticed this noise earlier when we went to leave to go away?? Its the first time Ive ever heard it and was just curious if anyone has encountered this or know what it is??
djr1973 is offline
Old 11-09-2009, 07:58 PM
jvm051's Avatar
My guess is you are just hearing the gas tank? Was the tank mostly full when you heard the noise?
jvm051 is offline
Old 11-09-2009, 07:59 PM
djr1973's Avatar
yes, it was full, I just filled it up yesterday afternoon, and have maybe 20 miles burned off of it.
djr1973 is offline
Old 11-09-2009, 08:02 PM
hyperv6's Avatar
Check you antifreeze it may be low or you have air in the system. Low Antifreeze or air will make the dash sound like that.
hyperv6 is offline
Old 11-09-2009, 08:05 PM
djr1973's Avatar
Ok, I will check it out tomorrow.
djr1973 is offline
Old 11-09-2009, 08:40 PM
J W Davis's Avatar
Slosh sound too...
My '08 has had that same noise for about a year, it only does it when I first start the car in the mornings or evenings after sitting for more than 6 hours.
I figure it is just air in the system that has to flush thru the cooling and heater, even though the system is full.
I just ignore it to the point that I had forgotten about it till I read this thread.
Would like to know what and how to cure....if possible.
J W Davis is offline
Old 11-09-2009, 09:45 PM
oneton's Avatar
I would say it's low on coolant! Look at it after the car has set overnight before starting. Remove cap and look there not in jug.
oneton is offline
Old 11-14-2009, 10:20 PM
jvm051's Avatar
I may have been wrong about the gas tank being the cause of the noise. This morning I had to return my wife's rental Impala and the tank was almost empty and I heard the sloshing sound. I have yet to hear it in my HHR. That being said I'm not sure anymore. When I had my Honda Fit I could hear the gas sloshing around when it was full, but this sounded different.
jvm051 is offline
Old 01-11-2010, 04:40 PM
mitzkity's Avatar
I love this forum!! All I did was search on "sloshing" and there was my solution. My car sloshes also when I first turn it on, and I just recently heard it...where do I look for the coolant - left, right, or middle...I bet mine is low. At 3+ yrs old and only 19K miles on it, it doesn't get a lot of servicing.
mitzkity is offline
Old 01-12-2010, 04:15 AM
biglefthhr's Avatar
not an expert
but I had the same issue, the coolant was low I filled the radiator first and allowed it to run with the cap off to get the air out, then I filled the overflow and poof sloshing sound gone, it is air in the system moving thru the heater core under the dash and thats what you hear...hope this helps!!!!
biglefthhr is offline
Quick Reply: Sloshing noise
