Smell of fuel/fumes inside the cabin
Old Dec 31, 2012 | 03:32 PM
IgottaWoody's Avatar
have someone hold a rag over tail pipe and then listen up close to flex pipe and if is leaking it will be noisy..and while carbon M may be odorless, the unburned fuel is not....and these cars are not 100% efficient.
Old Dec 31, 2012 | 04:12 PM
DaytonaBlueMetallic's Avatar
Good idea, I'll do that ASAP. I'm at work right now, but I'll do it as soon as I get out of here! Thank you!
Old Jan 2, 2013 | 02:10 PM
UPDATE: I found out why it was smelling like fumes in my car. Somehow the oil filler cap dissapeared off of the engine (I do my own oil changes, and I know for a fact I put that thing back in the last time I did it.) I have no idea how this happened, but I assume it probably flew off in the automated car wash I've been taking my car to. (I normally wash it on my own, but it's below freezing on a daily basis in Wisconsin right now.
Old Jan 2, 2013 | 05:20 PM
recap and let us know if this resolves the issue
Old Jan 3, 2013 | 08:39 AM
Originally Posted by DaytonaBlueMetallic
In the last 2 or 3 days, my HHR has developed a weird intermittent issue. Now normally, I would say my exhaust got disconnected, or something of that nature, but the whole system is fine.
When the car is sitting still, it will sometimes start to smell like exhaust in the car (not like burning oil or anything.) It can also get quite bad at low speeds.
I immediately thought that the car might be running hot, but the engine temp always stays in the range of 185 -195 in normal running conditions, so I ticked that off the list.
I thought of an oil leak next. Looked under the hood, under the car...not happening.
Does anyone have any experience with this? Should I be worried about being asphyxiated in this thing?
We apologize for any frustrations you may be experiencing. Have you been to a dealership for a diagnosis? Also, I can check your VIN to see if there is anything applicable to your vehicle.
Brandon (assisting Michelle)
Chevrolet Customer Service
Old Jan 3, 2013 | 09:14 AM
solman98's Avatar
Well, if you do your own work, you must have missed this step.... It happens....... Highly doubt any car wash would knock it off.
What is your oil level and how long has it been since the last oil change? Just thinking of possible contamination.
Old Jan 3, 2013 | 03:44 PM
Good point solman98 , I'd change the oil ad oil filter again
Old Jan 16, 2013 | 09:03 PM
UPDATE! The flex pipe is fine. The stock oil fill reservoir somehow miraculously flew off. I bought an aftermarket cap, problem fixed.
Old Jan 18, 2013 | 08:31 PM
I got an aftermarket cap from O'reilly Auto Parts, problem's gone.
Old Jan 18, 2013 | 08:36 PM
Oil level is fine, and the oil seems to be clean, last change was in October, and my oil indicator still shows 77% life left on the change.
I'll probably have the oil and filter changed when I have some new tires slapped on this weekend, just because I'm winter lazy.
edanramos
Jan 1, 2013 05:36 PM
hhrokie
Jun 21, 2012 02:24 PM
Joepoppa1
Jan 19, 2012 10:02 AM
IndianaJ.J.
Dec 6, 2011 07:18 PM
blue car
May 31, 2010 01:14 AM
