Spark plugs change
Old Sep 16, 2016 | 09:09 AM
aradmahogany's Avatar
Turn till tight then about an 1/8th or 1/4 turn after that. No more or less. Otherwise just torque em to I THINK 15 FT/LB
Old Dec 6, 2023 | 06:17 PM
shyoung2's Avatar
Don,
Would you recommend OEM or aftermarket or does it even matter? The car has 140,000 miles only thinking of changing because I have the opportunity to do so!
Thanks,
Shawn
Old Dec 6, 2023 | 08:14 PM
If you are asking about spark plugs use ONLY ACDelco 41-103. They should be changed at 100,000 miles, many last much longer.
Old Dec 6, 2023 | 08:28 PM
Just like you said in post #2!
Old Dec 6, 2023 | 09:24 PM
5 years ago.
Old Dec 7, 2023 | 06:55 AM
  #26
The song remains the same! As Donbrew states only install those specific spark plugs
Old Dec 7, 2023 | 06:13 PM
  #27
PulpFriction's Avatar
$3 x 4 = $12 rebate on 4 iridium plugs through the end of the year. Can be submitted on line.
Old Dec 7, 2023 | 07:57 PM
  #28
And installing them in a hot engine, then torque to spec, can cause the threads to pull (strip) as engine cools & contracts.
Cold install is safest bet. .
Old Jan 26, 2024 | 11:20 AM
  #29
Beejmamdude's Avatar
DO NOT TOUCH THE GAP. GET ONLY 41-103.
41-103 comes gapped correctly and can be damaged trying to change. Other cheap plugs may have a different spec, plugs are different. Somebody may have fat fingers. Trust the box, not the internet typing skills.
Change them when you want to; but, the "book" says 100,000 miles. I have seen them last much longer.
From the Service Manual:
hey Donbrew. Just to be clear Ac Delco 41-103 is one size right. Cause amazon is telling me Ac Delco 41-103 does not fit my HHR I've attached a screen shot below.
Old Jan 26, 2024 | 11:45 AM
  #30
Amazon’s fit guide is WRONG.
Look in your owners manual. The AC Delco part # is right there.
41-103
