Speakers
Old Jul 27, 2024 | 12:42 PM
Alkost01's Avatar
Speakers
All four door speakers go on and off randomly.
Is it the radio or the speakers?
Sometimes all four go off or just two of them.
Thanks!
Old Jul 27, 2024 | 12:51 PM
Lonwane's Avatar
More than likely it's the speakers.
They don't play well with water.
Go to Crutchfield for replacements.
Old Jul 27, 2024 | 01:41 PM
Alkost01's Avatar
Thanks for the info!
Old Jul 27, 2024 | 02:00 PM
Really they offer great selection of speakers, wire harnesses and if you want just see the size of speakers you need to fit your HHR and shop around
https://www.crutchfield.com/S-9tm70HiO4bU/
Old Jul 28, 2024 | 08:23 AM
PulpFriction's Avatar
The base speakers are junk, but the wires and connectors fail too. Every cheapie aftermarket speakers will be a big improvement.
Just replace all 4. 6.5” diameter. Ish.
Do not attempt to use the old connectors. Running larger wires highly recommended.
The OE speakers ha wired mounts, but if you replace with those, they’ll just fail again. Get these to make aftermarket replacements painless and preserve OEM appearance. Cut off the plugs and solder the new pigtails in.
Lethal Tendencies
Oct 6, 2016 06:57 AM
Jack Shaw
Sep 22, 2016 06:20 PM
agmc4me
Apr 18, 2015 04:11 PM
LawDog88
Dec 29, 2013 03:01 PM
Juan
Oct 11, 2007 10:04 PM
