Speedometer not working, not shifting from first
Old Mar 6, 2022 | 03:51 PM
hhrumadbruh's Avatar
Ok so this is the first time I've experienced this.
Speedometer didn't work, and car was stuck in first gear.
It corrected itself fairly quickly and I didn't experience the issue again.
Is this a sign of something?
Old Mar 6, 2022 | 04:21 PM
Could be a low voltage, battery issue.
Old Mar 6, 2022 | 04:31 PM
I don't think so! 14.4-15.2 usually. 2 batteries. But I'll keep an eye on stuff.
Old Mar 6, 2022 | 04:50 PM
Then check ground wire , cluster fuse and for loose connectors
Old Mar 6, 2022 | 04:55 PM
at the transmission?
Old Mar 6, 2022 | 05:10 PM
The output speed sensor on the transmission tells the TCM when to shift and the speedo. My guess is a wire is loose or compromised.
Old Mar 7, 2022 | 06:55 AM
Yes, at the transmission
alfolsee2000
Mar 11, 2022 09:22 PM
skyline26
Sep 9, 2013 03:34 PM
bad03xtreme
Aug 14, 2009 07:03 PM
SSilverbullet
Mar 25, 2009 05:48 PM
camaro98z28
Jul 27, 2008 12:22 PM
