Starter stays engaged
Old Jul 3, 2016 | 09:07 AM
aradmahogany's Avatar
THE MORE YOU KNOW! The one time I "accidentally" did that I was surprised that the car started. Never knew my accident was the right way to do it! And if the new ignition switch is "holding" the key in the start position...... Yeah sounds like an immediate fix is in order
Old Jul 3, 2016 | 09:12 AM
JOHNNYO's Avatar
Thanks oldblue that's what I was thinking since it worked fine before the new switch was installed. Any idea why it happens only once, after setting for hours?
Old Jul 3, 2016 | 09:20 AM
JOHNNYO's Avatar
Yes I'll let u know. I think this is a classic "rush to fix" as I call it. Sometimes the recall replacement is just as bad.
Curiously, the 2011 OM says to hold it until it starts! That could damage something.
Old Jul 3, 2016 | 09:27 AM
Lubrication?
There have been several reports here of botched installations of the recall. They seem to give the job to the newest kid in the shop and then rush him. I was lucky, the guy only forgot 1 of the tabs on the cover.
Old Jul 3, 2016 | 09:39 AM
JOHNNYO's Avatar
I'm sure that's very true. I've been around cars and trucks all my life. I've seen and heard all kinds of stories about service screw ups. There are very few true mechanics left. I'm not a pro by any sense of the word, but I can fix a lot of issues. That's why these sites are so great for asking opinions
Old Jul 3, 2016 | 09:59 AM
JOHNNYO's Avatar
Yes RJ it sticks in the start position for a second or two, only once then will not do it again till the car sets for a period of time.
Old Jul 9, 2016 | 02:06 PM
JOHNNYO's Avatar
Replaced ignition switch problem fixed
Old Jul 9, 2016 | 02:28 PM
Good deal. Glad it's resolved, and thanks for getting back with the fix - it just might help someone else out down the road.
Old Jul 9, 2016 | 02:38 PM
On a side note, I have been starting my car as per donbrew instructions ever since reading this. The engine starter seems to ony make a noise once and the engine turns over in less thatn a second. I then tried it the old way and held the key and the starter actually turned twiceand the engine took about a half second longer to start (rough estimate I wasnt using a stopwatch). Seems to like starting donbrews way more I would say!
2005HHRauto
2.0L Performance Tech
Jul 3, 2016 10:44 AM
en0oNmAI
Jul 20, 2006 12:02 AM
JonyyB
May 15, 2006 10:44 PM
CheckSando
May 7, 2006 04:15 PM
SIHHR
Mar 5, 2006 08:27 PM
