Starting problems
Old Jun 30, 2014 | 12:22 PM
nycamper's Avatar
Originally Posted by fastsuv
Mine threw a code because it had a crack in it and leaked. The emission system does a leak test every so often and flags a slow leak or a fast leak.
If it was stuck closed, I don't know if it would give any error codes. I think the most likely scenario for your case would be the solenoid stuck closed, not allowing the vapors to vent, causing a pressure buildup in the fuel system.
I agree with the others that this is a likely possibility in your case. It's worth it to spend the $30 and try it first.
Steve
Great thank you! Haven't had a lot of problems with her so this is all new to me! Thank you for all the advise.
Old Jun 30, 2014 | 12:46 PM
Look in the common parts thread for part numbers. The valve runs about $18, but you will need a wiring harness adapter, they cost about the same, sometimes it is included which explains the wide variety of prices.
Old Jun 30, 2014 | 02:38 PM
Here's a how-to on it's replacement - looks like an easy job once you get under the vehicle: https://www.chevyhhr.net/forums/how-...acement-44780/
Old Jun 30, 2014 | 02:43 PM
nycamper's Avatar
Thank you!
Old Jul 24, 2014 | 08:59 AM
nycamper's Avatar
Guess its good I asked you all about this, stopped to have my check engine light diagnosed and this time this is the code that came up instead of another sensor that is bad! Thanks again for all your help! Going to crawl under it tonight and take a look!
Old Aug 7, 2014 | 07:59 AM
nycamper's Avatar
Can anyone tell me where to buy the parts for this? Apparently all we have is people that don't know what they are doing at the local parts places. Been trying to find a sensor for under the hood too...ugh
Old Aug 7, 2014 | 08:36 AM
Advance, AutoZone,eBay all have them.
Old Aug 7, 2014 | 09:39 AM
nycamper's Avatar
2006 CHEVROLET HHR 2.2L L4 : Emission : Vapor Canister Purge Valve
Price
ACDELCO Part # 215573 {#22728653}
CANISTER,EVAP EMIS (W/O vent valve SOL)
Part Image
Choose: [Wholesaler Closeout -- 30 Day Warranty] (Only 5 Remaining) ($11.18) [Regular Inventory] ($88.89)
$11.18
DORMAN Part # 911032 {#12597567}
Part Image
$18.07
ACDELCO Part # 2141680 {#12597567} VALVE ONLY One of our most popular parts
VALVE,Evaporative Emission Canister PURGE SOL
Part Image
$22.79
STANDARD MOTOR PRODUCTS Part # CP471 {#15137021, CP455} SOLENOID; Pin Terminals; Terminal Gender: Male; Number of Terminals: 2;Number of Ports: 2;Number of Hose Connectors: 2; Hose Size - mm: 8 mm; Hose Size - Inches: 5/16"; Connector Gender: Male
Part Image
$23.79
AIRTEX / WELLS Part # 2M1077 {Click Info Link for Alternate/OEM Part Numbers} SOLENOID
Part Image
$26.79
Vapor Canister Vent Solenoid
Close Save My Place Print Send these listings to a friend Filter These Part Listings
Related PartsVapor Canister Vent Solenoid Connector Choose for Me to Minimize Cost
2006 CHEVROLET HHR 2.2L L4 : Emission : Vapor Canister Vent Solenoid
Price
ACDELCO Part # 2142341 {Click Info Link for Alternate/OEM Part Numbers}
VALVE,Evaporative Emission Canister VENT SOL MUST USE TOGETHER WITH JUMPER HARN 19257603
Part Image
$16.24
AIRTEX / WELLS Part # 2M1117 {#25932567}
May Require 1P1793 Jumper Harness Connector for Installation because of OEM Redesigned Vent Solenoid (Only 2 Remaining)
Part Image
$16.38
STANDARD MOTOR PRODUCTS Part # CVS33 Canister Vent Solenoid; Pin Terminals; Terminal Gender: Male; Number of Terminals: 2;Number of Ports: 1;Number of Hose Connectors: 2; Hose Size - Inches: 5/8"; Connector Gender: Female
Part Image
$20.79
These are what I am finding online...not sure which I need.
Old Aug 7, 2014 | 12:35 PM
I don't know either. Have you followed any of the above advice? Like following links and going to the common parts thread and doing testing.
You never did post a code number.
Old Aug 7, 2014 | 12:45 PM
nycamper's Avatar
I didn't post a code because everytime I check it, it pulls the code for the bad sensor under the hood for something else not this problem. I have tried searching and calling around but there seems to be different parts etc and no one knows what I am talking about.
