Stealership tried to rip me off on repairs to my SS
Old Jul 19, 2017 | 12:19 PM
Whatever it is, doesn't matter. It's not likely that any of us can measure gp/s. The thing is, if they didn't say what codes they were chasing, who can tell if they have any idea what they're doing?
Added to the BS upselling, I would tend to be irritated by this dealer also.
DB, maybe if you called them, they would have a record of what codes were present.
Old Jul 19, 2017 | 12:26 PM
DrLoch's Avatar
Originally Posted by Oldblue
A gram is weight
Air flow is measured CFM (cubic feet per minute)
Not to get picky, but I'm not blowing smoke..
This is from HPTuners, shows lbs per hour but I can change it to any unit of measurement I like.
The air we breathe has weight. At sea level a 1 foot square of air weights ~ 14.5 or 1 bar. The air an engine ingests has weight as well. Why do you think they call it a mass air sensor? It's not a CFM sensor.
Old Jul 19, 2017 | 01:08 PM
Yes it does.
Back in my firefighting days, I noticed that full SCBA tanks weighed more than empty ones.
Crudely weighed them one day. The full ones with 45 cubic feet of air at 2200 psi would weigh 2-3 pounds more than the empties.
Who knew that regular compressed air could weigh that much.
Old Jul 19, 2017 | 04:12 PM
K, I'm schooled, but a gram is a measure for weight and air is measured in CFM, right?
I'm seeing air is 14.7 lbs per square inch at sea level , also gravity's weight
https://www.google.ca/search?q=how+m...&client=safari
Old Jul 19, 2017 | 05:13 PM
No, technically, gram is a unit of mass(how much matter). Weight is measured as newtowns, weight refers to the force exerted on an object by gravity. (from Wiki)
A 100 gram object will 'weigh' differently with a different gravity applied.(but it's still 100 grams)
Is anybody's mind blown yet?
Old Jul 19, 2017 | 05:22 PM
Alrighty, I'll buy my tea in grams at a higher altitude so the atmospheric pressure is less.
That's why I had to rejet the carbs at Mile High in Denver.
What is gram (g or gm)? - Definition from WhatIs.com
Old Jul 19, 2017 | 06:13 PM
But you won't get a discount on your tea, if it's the same amount of grams. ....something about the price of tea in china....
Old Jul 20, 2017 | 07:24 AM
DrLoch's Avatar
Copy That Now that we've taken this way out there. Main thing, It was broke, now it's fixed and the MAF sensor appeared to be the problem.
babeba67
Oct 13, 2014 01:53 PM
HardyHarHHR
Apr 29, 2010 07:17 AM
nick's dad
Jul 7, 2008 04:12 PM
quest51210
18
Oct 16, 2007 01:55 AM
GDZHHR
May 13, 2007 12:31 AM
