Steering Grind?
Old Apr 14, 2015 | 11:49 AM
Originally Posted by bursjon
if you go into his profile thy are in there.
That is true bursjon.
But the point of my other thread was to "remind" donbrew. He often refers people to the very helpful links in his signature. On occasion, those links don't show in his posts signature. I was just reminding him of that.
The regulars here know of his helpful links, but some of the newbies may be confused if they look and see a "linkless" signature when he posts up in another thread.
Old Apr 14, 2015 | 12:23 PM
DrLoch's Avatar
Hey donbrew.
Remember that the links in your sig sometimes don't appear. Seems to be related to what device you post from.
I'm glad you made a comment on that and not me..
Old Apr 14, 2015 | 12:56 PM
I think I finally fixed it. Sorry, I had done a work around earlier, but it broke ,too.
I swear my Sig showed on my first post this morning, I spent several minutes making it show.
Old Apr 14, 2015 | 12:59 PM
Well, my vote goes to sway bar bushings n links. First. Anyway.
Old Apr 14, 2015 | 01:51 PM
hhrss10's Avatar
Mine started making a popping noise a couple of weeks ago that continued to get worse over the next day. I knew it was coming from the front driver side so I got my brother to shake the car to make the make the popping sound. I reached under placing my hand on different parts to see if I could feel where the sound was coming from and it was the sway bar link. The bottom bolt had come loose and after tightening it, the noise is gone!
Old Apr 15, 2015 | 06:33 AM
bursjon's Avatar
Here's a vid of the noise
Old Apr 15, 2015 | 06:38 AM
Sounds like intermediate shaft u-joint
Old Apr 15, 2015 | 06:45 AM
bursjon's Avatar
The U-Joint under the dash has been greased. I may try and oil the shaft on the out side of the car. Could it be the spline the connects inside to out at the firewall?
Old Apr 15, 2015 | 07:00 AM
Yes
Old Apr 15, 2015 | 07:15 AM
Grease does not repair worn out parts.
That must be what they meant by "top of the rack".
