Steering hanging up
Steering hanging up
Hey everybody, I’ve read a ton of forums and I need some help trying to narrow down an issue. I got an oil change 3 days ago and since then I’ve noticed the steering is getting hung up when I try and turn. At slow speeds or when backing out of a parking lot, the steering can kind of bind up on me but it seems like if I go back a little bit further it’ll get itself over that hump and let me turn the wheel. At higher speeds it will still tense up but still turn enough to get around so long as I take it somewhat slow and widen my turn. It’s intermittent but I’m worried not knowing exactly what the problem is. I’ve read threads about the rack and pinion, EPS motor, and intermediate steering shaft. I do have a rattle when I brake in a straight line but that hasn’t had any effect on the car’s performance. Can anybody point me in the right direction?
I did just get confirmation that the EPS motor was changed 6 years ago, but the cars got upwards of 50,000 miles since then. Within the past year I’ve changed all inner and outer tie rods, stabilizer links, and control arms that were starting to show signs of wear.
Haven’t yet, but will this afternoon. They were replaced within the last 4-5 years or so I was told. I’ll definitely take a look. Never thought that would affect the steering like that. Thanks for the tip!
It’s been right around a week. It’s on the passenger side right where my ac compressor drips so there’s no telling. Right now I’m looking at just changing the entire rack. But somebody told me you could grease these racks, like it had grease points? Is that true? I don’t think it is, I just want to make sure.
No there is no grease fitting, you clean out all the old grease and slop in new grease.
easier and cleaner to replace the steering rack.
Don’t forget the discount code from RockAuto!
https://www.chevyhhr.net/forums/www....ad.php?t=58948
