Strange sound
Old Sep 27, 2006 | 01:06 AM
  #31
GhstRider's Avatar
I found out the "LOUD" thumping noise the hard way. I was going about 65+ and I rolled the back 2 windows down and kept the 2 front windows up. **DO NOT TRY THIS!!** After I rolled them back up I seriously thought I blew out my eardrums because it hurt so bad.
Old May 21, 2007 | 09:12 PM
  #32
txbowhunter's Avatar
Originally Posted by thedonn007
If you really want to experience it, leave the front windows closed and open both rear windows all the way.
DON'T EVEN TRY
If you like your hearing at all and don't want a serious earache for the next couple of hours don't try this at home folks (pun intended). But in all seriousness don't try this it will hurt like H***, trust me I know, I tired it one day on the way home from work and it like to killed me. Mind you I like my music loud too, and it was UNBEARABLE, even with all 4 down and the sunroof open it was still louder than I could stand at 70 mph.
Old May 21, 2007 | 09:48 PM
  #33
TomsHHR's Avatar
This is where the words "air buffeting" came about through the threads...
Old May 21, 2007 | 09:57 PM
  #34
Snoopy's Avatar
Hmmmmm....
Let's see. Pressure in.....pressure out (relieved). Sounds like that could be a worthwhile mod.
I believe, there is supposed to be some relief built in....probably not effective enough, however. My truck, had those vents that had a rubber one-way flap. When you closed the door, it allowed the "compacted" air to escape.
What is the louvered panel, on the passenger side, of the cargo area??
Old May 21, 2007 | 11:16 PM
  #35
R CA HHR's Avatar
I have this problem only with the sunroof open and the windows all up. I have not tried the rear only down on the highway, yet. I'll try it at a slower speed just to see if its the same sound.
Old May 21, 2007 | 11:24 PM
  #36
35 mph should be all that is needed.
Old Jun 24, 2007 | 03:26 PM
  #37
Silverado82354's Avatar
Interior throbbing when windows partially open?
I suspect I may not be the only one....? When I drive say above 30ish, with 2 or 3 windows partially open, I get this insessint throbbing in the interior of my lil'scooter. It's wickedly anoying and I'm trying to learn to tune it by opening different combinations of windows. I there a problem with some equalizervent , like in my silverado cab, that may be stuck shut. Or is this just another engineering nightmare ...?
Old Jun 24, 2007 | 03:27 PM
  #38
Just open them a little more.
Old Jun 24, 2007 | 03:29 PM
  #39
Size:  5.6 KB to the site!!!
Check out this thread: Window Noise
Old Jun 24, 2007 | 05:25 PM
  #40
nfboy's Avatar
This occurs with any vehicle that is wagon-like. I think it has to do with air forced into the car through the open windows getting "trapped" as it hits the inside rear of the car which is sort of a "container" catching wind.
