Sunroof
Old Feb 27, 2016 | 01:32 AM
jtfrog's Avatar
Sunroof
I have an 08 lt2. The other day I accidentally pushed both sunroof buttons at the same time. Now the sunroof close within about 3 inches from closing and reverses and opens. It wil close if I hold the button.
Old Feb 27, 2016 | 03:18 PM
Close the roof, open the rear hatch, disconnected the negative cable to the battery for 30 minutes, put a towel over the hatch latch so it can't close on you.
After the 30 minutes reconnect the battery, start the HHR and it should be back to normal
Old Feb 29, 2016 | 10:30 AM
jtfrog's Avatar
I pulled the positive off, is this the same thing? Problem still exists.
Old Feb 29, 2016 | 10:33 AM
No the positive can spark and while undoing the clamp your wrench could contact ground and short out the battery.
Ok how long was it disconnected?
Over 15 minutes?
You might need to replace the switches
Old Feb 29, 2016 | 11:28 AM
Since you clearly can't follow directions; did you open the hatch and pull the cargo floor up to get to the battery? Or did you think the black boxey thing under the hood is the battery?
Old Feb 29, 2016 | 11:57 AM
jtfrog's Avatar
Battery in back, off for 30min.
Old Feb 29, 2016 | 11:58 AM
jtfrog's Avatar
I will try negative.
Old Feb 29, 2016 | 12:01 PM
The positive will have the same reset effect. But the negative is the much safer way to do it.
Old Feb 29, 2016 | 01:25 PM
Just in case
Chevrolet GM 06 08 HHR Sunroof Switch 15234114 | eBay
bartman
Apr 26, 2011 12:22 AM
SIHHR
17
Feb 21, 2007 06:04 AM
Lee3333
Jun 23, 2006 03:07 PM
Lee3333
May 15, 2006 10:05 AM
adamlowery
Feb 13, 2006 12:35 PM
