Sunroof
Old Jan 14, 2025 | 11:16 AM
1st post says all the wiring was cut out of the car. Now you’re saying all the lights work ?
Can’t be both. So what’s the true story here ?
If you don’t know about BCM’s, modern wiring, 5 volt reference systems and OBD systems, then your best bet is to leave it alone.
Shorting out the wiring or worse case scenario catching it on fire.
Old Jan 14, 2025 | 11:24 AM
dragnwagn's Avatar
It has a aftermarket wiring harness in it. Yes the car is street legal with working lights, wipers, brakes and a bad ass motor. Just trying to make it more comfortable to drive it. In the heat and cold.
Thanks Jeff
Old Jan 14, 2025 | 11:41 AM
Well, once you get the HVAC going, you won't need the sunroof.
When I had a car with a sunroof, after a few times, I never wanted to use it. It just let too much heat in, never even pulled the inside cover back anymore.
Then eventually, with use, it will leak.
Old Jan 14, 2025 | 11:52 AM
dragnwagn's Avatar
I know but I just want it to work, its there it should work.
Old Jan 14, 2025 | 12:21 PM
Bonez's Avatar
Originally Posted by dragnwagn
I don't know what a BCM is or do.
BCM is Body Control Module and ECM is Engine Control Module... since the car has been modified you will need to wire directly to the sunroof motor and whatever switch you are going to use. Find the hot and ground at the motor and go from there, reverse polarity to open/close unless its a 3 wire operation Hot ground Hot
Old Jan 14, 2025 | 12:23 PM
Bonez's Avatar
Thanks Jeff
Pictures would be nice.... of the car as well as the issues.
Old Jan 14, 2025 | 01:17 PM
dragnwagn's Avatar
sunroof
sorry for pic beaning so big
Old Jan 14, 2025 | 01:31 PM
Just an HHR shell body. Engine, suspension and everything else is non HHR. Asking for help on this HHR forum is the wrong place. Contact a performance shop or mod shop for help.
Old Jan 14, 2025 | 01:34 PM
dragnwagn's Avatar
sunroof
I should still make the sunroof work, all the component's are there, Switches and the wiring
Old Jan 14, 2025 | 02:30 PM
Then you only need to determine which is power and which is ground in the area of the sunroof switch se post #1.
https://www.chevyhhr.net/forums/prob...-issues-64241/
