Sunroof
Old Jan 14, 2025 | 03:05 PM
dragnwagn's Avatar
I know is power and ground. According to the wiring diagram it should work but it don't, I think I am missing something.
Thanks Jeff
Old Jan 14, 2025 | 04:18 PM
Here's another good thread
https://www.chevyhhr.net/forums/prob...-issues-64241/
Old Jan 14, 2025 | 04:21 PM
dragnwagn's Avatar
Thanks Jeff
Old Jan 14, 2025 | 06:11 PM
Originally Posted by Oldblue
Then you only need to determine which is power and which is ground in the area of the sunroof switch se post #1.
The problem is the "enable"; which seems to be a digital signal. Tan wires are mostly either the low or high speed gmlan -. So, I would try a ground signal.
According to this if you ground that wire the sunroof should function even with the key off. If it is "open" the sunroof won't function; you already know that.
Old Jan 14, 2025 | 06:58 PM
dragnwagn's Avatar
sunroof
Thanks Jeff
Old Jan 15, 2025 | 09:08 AM
  #26
PulpFriction's Avatar
In older cars, from a cost/benefit perspective, often the best fix for a malfunctioning sunroof is to get it closed by any means needed, pull the fuse, and seal it shut. In this case, because it was intentionally relieved of its workings, restoring function is far more complicated. But, hey, if it’s a labor of love and hang the cost, by all means, have at it.
Old Jan 15, 2025 | 01:56 PM
  #27
dragnwagn's Avatar
Sunroof
Thank you all I made it WORK. It was the Tan wire, It needed to be grounded. thank you again.
Old Jan 15, 2025 | 03:50 PM
  #28
Awesome, thanks for the follow up
Old Jan 15, 2025 | 04:08 PM
  #29
Caban64
Aug 14, 2023 11:23 AM
OKIE SS
Oct 23, 2021 05:08 PM
Brewer13
Feb 23, 2011 11:20 AM
Teflonworm
Jul 24, 2006 07:40 AM
Lee3333
May 15, 2006 10:05 AM
