sunroof windscreen needs fixing!
Old May 13, 2011 | 10:07 AM
holmesdude's Avatar
A short while ago I was driving with my sunroof open. When I parked the car I went to close the roof. When I did I noticed the windscreen didnot close properly. I got out to investigate and discovered the bracket on passenger side of screen broke and no longer operated properly when the window slid close. I don't know how this could have happened. I've not had problems with this before. Since this is an automatic operation I know no ones hand could have broken this bracket.
This bracket is riveted on and it seems like a pretty close fit. Has anyone else had to fix this and if so how?
Old May 13, 2011 | 10:15 AM
ChevyMgr's Avatar
Two fixes:
https://www.chevyhhr.net/forums/how-tutorial-library-21/sunroof-quick-fix-those-without-warranty-coverage-11629/
https://www.chevyhhr.net/forums/showthread.php?p=333293
Old May 13, 2011 | 03:00 PM
holmesdude's Avatar
Thanks;
Both seem like a good fix. The one talks about removing the headline as instructed by SI. I am not sure what SI is and all I have is a manual that doesn't mention anything about the sunroof. If I can't figure that out I'll do a deflector install.
Old May 13, 2011 | 03:12 PM
ChevyMgr's Avatar
SI is the online service manual for GM techs.
Old May 14, 2011 | 07:53 AM
Beachbum1's Avatar
I disconnected my screen entirely and placed a deflector on top. Works great and am very pleased. got the deflector from and ad on this site.
beachbum1
Old Jan 23, 2012 | 04:39 PM
GOLFHHR's Avatar
Easy Fix
I replaced the broken bracket today to fix the windscreen, easy fix about 1/2 hr. You do not need to remove the headliner which is indicated on the TSB. Follow the TSB instructions, remove the rivet just be carefull when drilling and punching out rivet not to damage the headliner. Use a rivet tool with a narrow head which is required to be able to seat the rivets in place. Rivet the bracket from the top, no clamp is required. Just use the old broken bracket as a template to drill 2 1/8 holes in the new bracket. Presto your done, easy as pie.
Old Jan 23, 2012 | 06:04 PM
bigjacksauto's Avatar
Wow that's great news.
this is the first that I have heard of anyone being able to fix this issue without going to. The dealer.
Any pictures of the procedure
Old Jan 23, 2012 | 06:30 PM
GOLFHHR's Avatar
Just use the TSB pictures on this post from the Chevy Mgr. I think that in the TSB they removed the headliner either 1) to drill the holes in the new bracket from inside the car rather than using the old bracket as a template and drill holes on the bench. Or 2) On the TSB they riveted the bracket from the bottom, they may have had a rivet gun that had too large a head and they were unable to rivet the bracket from the top. My rivet gun has a slimmer head design than some and I was able to rivet the bracket from the top.
Old Jan 31, 2012 | 10:16 AM
manos de lumbre's Avatar
Hey GOLFHHR, thanks for the info. I really didn't think it was necessary to remove the head liner to pop rivet the new bracket. I ordered a new bracket yesterday. I’m going to attempt the repair without removing the headliner. I’ll take pictures and let ya’ll know how it goes.
DaytonaBlueMetallic
Mar 31, 2021 11:05 PM
pumpkinqueen
South East
Feb 23, 2015 06:47 AM
CARRS 06 HHR
May 16, 2013 03:06 PM
Goose
Feb 28, 2011 06:58 AM
