suspension damage help
Old Jan 23, 2017 | 02:50 PM
The bank doesn't own your car? That is an oddity.
1/2 inch drive and 3/8 and 1/2 drive metric socket set to 18mm, no special tools. Most used 10,12,14,18. 1/2 breaker bar is a good thing. You can usually "loan" tools from Autozone/Advance/O'Reilly.
Old Jan 23, 2017 | 04:23 PM
To bad about your HHR, you're gonna need a 21 mm or a 7/8 for the lower control arm rear bolts, 15 mm and 16 mm sockets for the ball joint pinch bolts, most of the bent parts would be the struts and tie rods, the inner ones require a special socket, you rent borrow from you local parts palace.
If you can take a couple of pictures of any part that looks bent post them up , we'll have a look!
Old Jan 24, 2017 | 10:54 AM
My bad, I was thinking the LCA bolt was an 18mm. If you get a deep 21MM you can torque your own wheel lugs.
Old Jan 24, 2017 | 11:17 AM
I use a 3/4 deep impact socket or a 19 mm for the lug nuts, and just a note the top nut on the strut piston rod is a 21 mm and a deep socket is required.
Old Jan 24, 2017 | 10:49 PM
Don06's Avatar
Originally Posted by AJuneman
Hi, very new to this forum. I just recently wrecked my car on some ice and need some tips on where to start repairing it.
Took it to my mechanic to have it looked over and they claim i need
  • sway bar links/ bushings
  • right front axle shaft bent
  • right front lower control arm and left front lower control arm bent
  • right front strut
  • right front spindle
they also listed an alignment, break pads/rotors, and tires. I'd like to fix this my self, but i'm not much of a mechanic. Is there anywhere I need to start first because I'm going to be doing this little by little. Are there certain brand name parts to get? special tools? should i have just left this up to the professional? or is it too far gone to be repaired?
Any information helps.
Thanks.
If you search online, parts can be found at decent prices.
You can buy a new pair of lower control arms complete with bushings and ball joints for $62.
Do they mean the spindle or hub because if the spindle was damaged they would replace both.
Hubs are $60/pair.
An axle shaft is $51.
Struts are $110 for a pair.
Sway bar links are $14.
Stabilizer bushings are $10.
Slotted and drilled rotors and ceramic pads are $62 per set.
So a little over $370 for parts which are fairly easy bolt ons.
Old Jan 25, 2017 | 12:00 AM
Wow - those prices are pretty good - where did you find them?
Looking at Autozone (picked at random):
Lower control arms: $133 ea = $266 for a pair
Hubs - $53 x2 = $106 for non ABS - or $98 x2 = $196 for the pair
Hub nut - $14 ea/$28 pair down to $5 ea or $10 for the pair
An axle shaft - $64
Struts are $143 ea. = $286
Sway bar links - $30 ea = $60
Stabilizer bushings - $20 for the pair
Slotted and drilled rotors - Regular rotors - $42 ea or $84 for the pair
ceramic pads - $44
and the total comes to $1030 plus tax - which is a far cry from $370.
Old Jan 25, 2017 | 08:25 AM
Hidden damage can be a real bugger to find AJuneman, sometimes it's only detectable by popping your HHR onto a frame jig, or checking dimensions with a tape measure to see if there's any structural deformation.
I have the "Crash Repair" specs on HHR's filed away somewhere, if you'd like to shoot me a PM with your e-mail address, I can send you a PDF of the specs when I find the hard drive they are stored on.
Might take a day or two to locate the files, just so you know.
Old Jan 25, 2017 | 08:57 AM
An axle shaft - $64
ceramic pads - $44
eBay is good!
Since the HHR has no "spindle" I am assuming they meant "knuckle".
Old Jan 25, 2017 | 09:19 AM
Originally Posted by donbrew
eBay is good!
True that.
What jumped out at me was the LCA's - I've never seen them that cheap anywhere (not even the stamped steel ones for the Cobalt).
Old Feb 1, 2017 | 12:20 PM
Don06's Avatar
An axle shaft - $64
ceramic pads - $44
I guess I should have put the links in the first time. I just did a google search for 2008 HHR and part description. I get a variety of vendors and prices. This is the way I buy most everything these days. I bought a window regulator for my pickup for $29 when it would have cost over $200 locally.
Control arms Shopping
Hubs HB613208PR - [Front Set] 2 Wheel Hub Bearing Assemblies - Prime Choice
New axle $63 rebuilt $38 08 2008 Chevrolet HHR CV Axle Assembly - Driveshaft & Axle - EMPI, USA Industries, Front Left, Front Right - PartsGeek
Struts Shopping
Sway bar links Shopping
Sway bar bushings 2006-2011 Chevrolet HHR Sway Bar Bushing - Suspension - Genuine, Front 06-11 HHR Sway Bar Bushing - 18619-01208193 - PartsGeek
Rotors and pads Shopping
There are also kits like this available for $357;
https://www.1aauto.com/suspension-ki...FUK5wAodkCEEbw
