Suspension Problems/noise?
Old Dec 27, 2011 | 11:29 AM
  #91
HoHoR's Avatar
Just bought my 08 panel Friday for an early x-mas gift and I too was concern about front & rear noise but, being a newbie and not familiar with 'normal' road noise, took it to my shop for a road test. Max said he didn't hear anything out of the norm up front but little clunking in rear and after a lift check, said probably a loose shock end. Will probably replace all stock shocks with an up-grade, nothing special..yet. Any suggestions?? Happy 2012
Old Dec 27, 2011 | 04:16 PM
  #92
Lee3333's Avatar
So you mean the bushings that go around the sway bar it self and hold it to the frame? I know in my case it was the end links that were bad-when the car was on a lift I could hold them in my hand and shake them and they would rattle and make noise. The sway bar seemed solid and I could not move it.
Old Dec 27, 2011 | 05:26 PM
  #93
Yes, both can cause a clunk noise. End links seem to be the more common, but the bushings wear and get hard with age (and cold) as well.
Old Dec 28, 2011 | 04:18 PM
  #94
calgaryhhr's Avatar
I wish I would have replaced the sway bar bushing on my HHR when I had the end links changed about a month ago.
Replacing the end link on my HHR reduced the noise by about 90% but there is still a bit of noise when I hit some bumps and that is likely due to the bushings. Oh well, I can live with this level of noise but it sure would be nice if it was completely silent.
thunderstruck88
30
Apr 26, 2015 04:41 PM
JOHNERICKSON
Maintenance and Upkeep
Jun 16, 2014 07:11 PM
fanbelt.1
Nov 4, 2013 09:51 AM
chefhhr
16
Jul 8, 2012 05:47 PM
Doog47
Nov 7, 2011 02:58 PM
