T/C light
Old Aug 6, 2015 | 02:05 PM
That would explain the t/c light.
Check the flex pipe for cracks.
Old Aug 6, 2015 | 02:09 PM
Dbeluscak's Avatar
Even a small vacuum leak will give ya P0171. Been there.
Old Aug 7, 2015 | 08:37 AM
dwarfracer1's Avatar
poured rain here yesterday, will try to do some more checking today. the intake pipe(about 3") was all broke so I taped it together could that give the code?
Old Aug 7, 2015 | 12:15 PM
Dbeluscak's Avatar
Um...definitely! Do yourself a favor, ditch that pick up the KN tube. 2005HHRAUTO, has said in the past it's one of the best mods to have. And it won't throw a CEL and doesn't need a tune. If your taping (lol) it up it will leak! It'll probably work for a bit, but invest when you get a chance.
Old Aug 7, 2015 | 04:29 PM
On a 2.4L, I doubt it, but maybe.
If P0171 is the ONLY code the possibility is high that the fuel pump is to blame. That is easy to check, with a fuel pressure gage.
There are two options: too much air (vacuum leak?), or not enough fuel (bad pump?).
Old Aug 7, 2015 | 06:32 PM
Dbeluscak's Avatar
Yeah I guess if it was all busted up and sucking air it's not really a leak...just going round the filter. donbrew's got the right idea. Check fuel pressure..
Old Aug 8, 2015 | 07:59 AM
will check fuel press, but wouldn't that cause hard starting? what's best way to check vacuum lines? vacuum pump?
Old Aug 8, 2015 | 11:50 AM
What vacuum lines?
Old Aug 8, 2015 | 12:45 PM
donbrew, the vacuum leak you referred to in your reply #15. just don't want to check more than I need to
P0171 is the only code I get other than t/c light
Old Aug 8, 2015 | 03:04 PM
well just finished up working on HHR, put in new ac/delco plugs, had autolites in it(gag), new air filter(it was filthy),new cabin filter (it also was filthy), also found a small tube ( 3/8-1/2") runs from valve cover to intake(between MAF & throttle body) was split on end & wasn't even hooked up?? hope this cures problems. thanks for all the input.
