View Poll Results: What happens if the coolant pipe tab breaks?
Take apart and replace...again...
0
0%
Tap hole and add set screw
0
0%
Nothing it will be fine as is
100.00%
Buy a ford. Hahaha
0
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Tab on coolant pipe broken
Old Nov 24, 2022 | 05:31 AM
Letfreedomreign's Avatar
I recently replaced my thermostat housing an on my first attempt at install the tab on the coolant pipe bent from ninety degrees to flat on the pipe. Bending it back up it snapped off. What are my options?
Old Nov 24, 2022 | 06:34 AM
If you got the tube back into position and there are no leaks, you’re good to go!
Old Nov 24, 2022 | 07:39 AM
greg8453's Avatar
What kind of poll is this?
Old Nov 24, 2022 | 08:06 AM
To see what should be done with the broken off tab in the water transfer pipe.
See it over there on the right end of the pipe!
Jit
Oct 17, 2019 03:57 PM
Kronikking
Sep 17, 2019 11:18 AM
DrLoch
Apr 9, 2016 07:47 AM
kornellred
Maintenance and Upkeep
Nov 28, 2011 12:28 PM
geg
Sep 15, 2011 02:52 AM
