Tach Stopped Working..:(
Old Oct 12, 2015 | 04:10 PM
SpeedDemon's Avatar
Unhappy Tach Stopped Working..:(
So here it is... My 2011 Chevy HHR Tachometer stopped working !
Any who i bought a simple cheep tach so that i can still monitor my RPMs, Picture below shows the Tachometer...
[/IMG]
As you can see i have it installed, power is hooked up and everything else. The only issue i am having is where to i put THE TACH SIGNAL WIRE!!! i have been researching for days... i know someone has done this its just the matter of finding them! i have already ran the wire threw the firewall. picture below.
i was going to just replace the assembly so that my gauge would work but after hearing the price hell no.. sorry for the pictures being sideways not sure why I bought the Hanes repair manual, nothing that i needed was found as far as this...
if anyone could shed some light on my day and help get this going i worship you! Thanks in Advance
Old Oct 12, 2015 | 04:51 PM
I would think the RPM is monitored by the ECM thru the crank position sensor, the Haynes manual should have the wiring diagram and which colour wire to tap in the gauge cluster harness. Is it the tach gone wonky or the sensor or the ECM?
Old Oct 12, 2015 | 05:36 PM
SpeedDemon's Avatar
IM 90% sure its the gauge, took it to a small town garage they said the motor in the gauge cluster was bad. It does not move at all i tested it for power in the line and the line is fine. So if the wire has power the sensor must be okay yet. so i need to tap into the CPS wire?
Old Oct 12, 2015 | 06:47 PM
FAQ: How do I hook up my tachometer?
Old Oct 12, 2015 | 07:38 PM
SpeedDemon's Avatar
thanks for that info, but i still need to know what wire is the signal for the RPM. i have not found much searching the web or my repair manual
Old Oct 12, 2015 | 08:47 PM
you may need one of these
Tach Driver, DIS Ignitions - 8913
Old Oct 12, 2015 | 11:48 PM
Lucky's Avatar
The factory gauge does not have a traditional tack wire signal going to it. The gauge cluster is a computer that gets its information from other computers like the ECM and they talk in computer Language.
Old Oct 13, 2015 | 01:39 AM
X2, it's a case of "Module A" communicating with "Module B" through the GM-LAN Can Bus duplexed wiring system.
No distributor, no tach drive, no tach signal to tap into, it's all 1's and 0's.
The only cure for a dead tach is to run the "Diagnostics Tree" using a Tech II, and then in 99% of the cases, the I/C has snuffed it. So you replace the Instrument Cluster, which needs programming to pair up with your HHR and recover your Odometer reading.
Not to knock small town garages or the techs who work in them, because some are incredibly competent, and their diagnosis of a bad I/C sounds spot on.
Old Oct 13, 2015 | 01:24 PM
SpeedDemon's Avatar
Thanks, i am looking into part 8913, I also ran into tach adapter 8910 would that work? it is also by msd. the 8913 looks more promising though..
Old Oct 13, 2015 | 06:07 PM
Contact MSD they are awesome folks, have helped me a lot with my old 355 SBC and resolving an issue with their ignition box and distributor.
They overnighted a new box , harness and distributor thru in plug wires a cap and rotor and a Blaster II coil
It turned out to be the ignition box, they waited six months until I brought the return products to their booth at a national event in Carlisle Pa.
Very nice folks to deal with!
Ambivalence
Jul 8, 2010 12:59 PM
rewcolee1
Aug 5, 2009 08:27 PM
SIHHR
Dec 6, 2008 02:59 PM
Kicker|MyU
Sep 19, 2008 08:00 PM
Dragula
Jun 19, 2008 06:11 AM
