Temp dial gets to red and no heat
Old Jan 30, 2019 | 09:49 AM
You say the coolant was changed 2000 miles ago, but do you know what they used?
Old Jan 30, 2019 | 09:50 AM
11bluemn's Avatar
Receipt says dexcool its all I know.
they don't give the empty jugs back.
Old Jan 30, 2019 | 09:59 AM
11bluemn's Avatar
Originally Posted by donbrew
Limp mode starts at around 230F-240F. The computer starts shutting cylinders down randomly. 250F is "catastrophic". You may have killed the engine.
it's still running
Old Jan 30, 2019 | 10:04 AM
My dad drove a 1953 Studebaker to the dealer to trade it in with a rod sticking out of the block. It was running.
Old Jan 30, 2019 | 10:09 AM
11bluemn's Avatar
You are probably right, I will just call the junk yard to come get it.
Old Jan 30, 2019 | 10:15 AM
Silverfox's Avatar
Has anybody checked the coolant to see what it reads for protection temp. Who knows if they had the proper mix when last installed.
When I had mine serviced by a my GM Dealer it read 42 degrees below shortly after words when their Lube dept. checked it as part of the oil change service.
Silverfox
Old Jan 30, 2019 | 10:25 AM
Straight Dexcool won’t cut it in the deep cold.
50% Dexcool and 50% distilled water is what I use up here .
Old Jan 30, 2019 | 12:28 PM
Cat Man HHR's Avatar
50/50 is normally -32F or -36C
I thought Dexcool was a pre-mix out of the container.
https://www.acdelcoarabia.com/acdelc...50-premix.html
Old Jan 30, 2019 | 01:07 PM
50/50 mix in the top bottle, straight Dexcool in the bottom
GM straight Dexcool
And a bunch of other manufacturers
https://www.google.ca/search?q=Dexco...iw=375&bih=549
Old Jan 30, 2019 | 01:35 PM
Thanks found the answer here for the 10-101.
https://www.jegs.com/i/ACDelco/065/10-101/10002/-1
