Temperature and blower direction will not change?
Old Nov 1, 2012 | 10:42 PM
irod87's Avatar
Exclamation Temperature and blower direction will not change?
I have a 2006 HHR and all of a sudden it will not change from cold to hot nor will the blower switch from head to feet or defrost. I have unplugged the unit and plugged back in, made sure the connection are tight. Unplugged the battery for a while and plugged it back in and nothing. Could it be the blend door actuator? I could not locate the blend door behind the glove box. Any suggestions?
Old Nov 2, 2012 | 05:04 AM
Did you check for voltage at the switches? Could be a fuse or relay. Try looking at fuse #10, #16 and relay#30 in the interior fuse block.
Old Nov 2, 2012 | 08:54 PM
irod87's Avatar
Yes we did also check the fuses and relay. I forgot to mention that.
Old Nov 2, 2012 | 10:12 PM
07azhhr's Avatar
The control head itself could be the issue.
PaperChaseHHR
Oct 8, 2013 04:22 AM
sleeper
Jan 29, 2012 01:09 AM
turbo ssei
May 12, 2010 08:02 AM
lynwoodg
Dec 19, 2009 08:42 AM
BritPaul
Sep 18, 2009 08:08 AM
