temperature up
Old Jul 13, 2017 | 05:54 PM
It also does that in defrost.
The fan should turn on, no A/C, at about 219F then run until about 180F (the temp the t-stat closes). Continuously if the A/C compressor is on. There may be a different AlGoreithm for turning the A/C off.
The computer should not be checking at startup; as far as I know, there is no feedback for the cooling fan.
Old Jul 13, 2017 | 05:59 PM
Conax's Avatar
Hey, DB, whattup?
Maybe the whooshing sound I hear at turning the key on or right after I turn it off is the fuel pump or something? Not the fan, I mean.
I was very happy that it worked fine after unhooking the negative cable.. woohoo, said I.
I sure do love this strange little 4 cylinder car. I get all worried when something ain't just right. Never cared about my old Merc' very much.
Old Jul 13, 2017 | 06:05 PM
Conax's Avatar
I reckon the last test I should do is take it for a spin with the A/C on, turn it off (no defrost or recirc) and see if the fan stops as it should.
Old Jul 13, 2017 | 06:55 PM
Conax's Avatar
I found out that once the A/C has been on, the fan runs until you turn of the ignition whether the A/c is on or off. I left it on five minutes, turned it off, turned the blower off and the fan still ran.
Shut off the car, waited a few minutes, coolant at 180, started the car- no fan.
This may be normal operation, I have no idea.
Not a big problem, just a weirdness. A quirk.
Old Jul 13, 2017 | 09:29 PM
prod's Avatar
Now that you mention it, that has happened to me before too, fan didnt shut off right away after AC use.
Old Jul 13, 2017 | 10:14 PM
  #26
Conax's Avatar
It makes sense if you figure if it's hot enough to run the A/C the driver would probably turn it back on or the radiator could probably use the help keeping things cool. It might be programmed that way. Then again I only take short rides so maybe after a while it would have stopped. ?
It is so impressive how the system keeps the coolant between 178 and 181 indefinitely with that fan running, in city driving on my old used car.
Old Jul 14, 2017 | 01:20 AM
  #27
McB_HHR's Avatar
GM has even used fan delay relays that would control the fan - even when off. Would not surprise me if they have fan controls based on criteria or thresholds on an HHR. A/C would be easy enough for them to use.
Old Jul 14, 2017 | 08:05 AM
  #28
There is a temp that makes the fan stay on after the engine is turned off. Something like 240F.
Yeah 240F, I been reading stuff that switches between C and F lately, so 140 didn't look that low.
Old Jul 14, 2017 | 10:19 AM
  #29
aradmahogany's Avatar
Don you mean 240 right? And, my fan almost always stays on after I cut the compressor off at least for a minute or two. I think the fan wont shut off until the car reaches a desired temp; like it runs on the same parameters that are in place when it turns on in traffic to cool the engine down
Old Jul 16, 2017 | 09:42 AM
  #30
Scouttster's Avatar
Reply
Florida is hot.. The car runs hot in stop and go traffic. I have gotten a good result and lower my temp faster by taking off all plastic guards covering the L and R side and top of radiator.. I know they probably direct fan air flow but results are positive.. Im also on the fence about running dex cool.. I personally like distilled water whereas its less viscous and gives up heat fast.. Please advise?
