Is there any part or actuator to fix AC Recirculation Air Door?
Old May 12, 2014 | 01:05 AM
Gsus's Avatar
The thing is that I have always fresh air, when I click on Recirculation option, nothing happen, so I would like to know if someone has have any problem there, or any advice of where to check or what piece could be the problem,... No codes on DIC about, the AC is ok just that thing that could be helpfull in how weather,
Thanks for your help
Old May 12, 2014 | 10:07 AM
It is called a Mode Actuator and Mode Door. Try GM parts.
Old May 12, 2014 | 11:26 AM
Gsus's Avatar
Hi donbrew,
Is it the same as HVAC Floor Mode Door Actuator?
or wich part do you think is the correct one?
thanks
Old May 12, 2014 | 12:03 PM
I think so. There are a few threads about the door and actuator, do the search thing.
Old May 12, 2014 | 12:19 PM
07azhhr's Avatar
Before condemning the actuator I must ask which vent setting you are using. The HVAC system in our cars will not go into recirculation mode if you have it on defrost or even mixed defrost/floor.
If it is a bad acutaor then the one you want is the "recirculation door". If you look at the link below you will see 3 actuators listed. Look at the notes for each and you will see what each one is used for.
A/C Heater Blend Door Actuator | 2007 Chevrolet HHR 4 Cylinders D 2.2L SFI DOHC | AutoZone.com
Old May 13, 2014 | 12:24 PM
Gsus's Avatar
Hi guys,
I know that recirculation does not work in all modes, I have tried in the correct way, but, it simply does not do anything, I have always air comming from outside.
What I have read and understood about A/C Heater Blend Door Actuator is that It divide heat air/cool air depending of the use, but I didnt read anything about recirculation. So I dont know if this is the correct part.
Regards
Old May 13, 2014 | 06:23 PM
07azhhr's Avatar
Did you read my full post above yours? I answered that for you and provided a link for you to see that there are different ones for each of the three functions.
Recirculation actuator moves a door that switches between outside air and inside air.
Temp actuator moves a door that switches between hot air and cold air.
Mode actuator moves a door that switches between dash/floor/defrost vents.
Old May 19, 2014 | 09:48 AM
Gsus's Avatar
Yes I did, I identified the part, thanks 07azhhr, I will check how difficult could it be...thanks
Zala
Sep 9, 2024 07:09 PM
arp
Jul 20, 2019 12:12 PM
Babbette
Jan 11, 2014 07:27 PM
pitbull76
Oct 9, 2011 01:42 PM
Markiemark
Mar 12, 2007 01:36 PM
