Thermostat
Old Oct 6, 2010 | 10:58 PM
Roscoemaries's Avatar
Thermostat
Had problem with temp gauge not working with engine light on. Switch out old stat and replace with new, the stat that came out was sealed close with heavy duty sealer,is that freaking normal?
Old Oct 6, 2010 | 11:44 PM
no. that is not normal.. Sounds like someone added some stop-leak ?
Old Oct 7, 2010 | 12:33 AM
Question
Or, the original gasket that seals the movable valve was badly
Malformed Like mine was when it was removed. If bad enough it could be mistaken for a black sealant rather than a black gasket. If it was a stop leak substance, I would have expected the thermostat would be in a sealed position, rather than jammed open which would typically be indicated by the temp digital display showing "----" and accompanied with the CEL.
But then again I maybe wrong. :)
Old Oct 7, 2010 | 12:40 AM
aaaah, the OP said it was sealed closed
Old Oct 7, 2010 | 11:20 AM
So noted. That seemed kinda odd, as the engine would have been overheating, and the gauge, I would have expected, would have been off the chart.
When the thermostat is removed, it is cooled, and therefore in the closed position - and I thought the old malformed gasket might have been mistaken for something else.
Old Oct 7, 2010 | 10:10 PM
thermostat
Yeah, might be old rubber gasket,just that it looked like a dam good squeeze seal job. Simple repair. I mean getting to the part rather easy.
Old Oct 7, 2010 | 11:35 PM
Agreed, & point taken...
06burntorange
Nov 11, 2013 12:32 PM
41pontiac
Mar 3, 2012 12:37 AM
nmnerf
Aug 14, 2011 08:27 AM
hurst2001
Mar 4, 2011 03:19 PM
