thermostat
Old Sep 6, 2016 | 10:27 AM
jtfrog's Avatar
thermostat
Thermostat failed again. No a/c temp. gauge on zero. Does the thermostat go in a certain way? Does it matter or just put it in.
Old Sep 6, 2016 | 11:18 AM
It only goes in one way. ie: take old one out - note how it is located, put the new one in the same way.
Old Sep 6, 2016 | 12:21 PM
jtfrog's Avatar
That's what I mean, you can put it in but it runs 360deg.
I mean turns around 360 deg.
Old Sep 6, 2016 | 12:47 PM
It drops in, not tab a into slot c.
They normally fail when the inner rubber gasket falls off and gets stuck holding the valve open. There are models available that don't have the inner gasket.
BTW, see that "EDIT" button in the bottom right of your post? Guess what it is for.
Old Sep 6, 2016 | 04:29 PM
jtfrog's Avatar
Thermostat had rubber inner O ring blown out.
Old Sep 6, 2016 | 04:40 PM
Look at your other thread about the thermostat and get the correct GM one from the dealership, look at it before you buy it, ensure it doesn't have the rubber piece!
Part number 12622410
Genuine SAAB Engine Coolant Thermostat (82 Deg) 12622410 -Free Shipping Available
Or here
GM OEM Engine Coolant Thermostat 12622410 | eBay
Or here
Ecotec Thermostat 12622410, Performance Autowerks
fastsuv
Nov 28, 2011 11:40 AM
HHorange
May 22, 2009 10:37 AM
Lee3333
Dec 27, 2007 08:16 PM
dinobass
Nov 20, 2006 03:18 PM
joesblackhhr
2.4L Performance Tech
31
Jul 20, 2006 04:28 PM
