Threw some new codes today
Old Dec 16, 2010 | 10:29 AM
bartSS's Avatar
Originally Posted by andyb
i'm at rt 83 & palatine rd in polo run. 2009 victory red, 13,000 miles. auto trans w/ gm upgrade done at rochenbach! low miles due to i ride my harley to work every day except for winter. bought the car 3-31-09 at stasek chevy.
funny thing, there is a black SS in my neighborhood ( w/ a ton more miles)!
I might have seen you around once or twice then
Old Dec 17, 2010 | 11:11 AM
camaro98z28's Avatar
Or the ring are gone and low compression..
Originally Posted by bartSS
if your CEL went on for a misfire then its gonna be a bad coil
Old Dec 17, 2010 | 11:32 AM
bartSS's Avatar
True
Old Dec 17, 2010 | 04:13 PM
THE BATMAN's Avatar
Yep bart still running orig plugs, 58,000 miles. No codes since. It's driving and running fine , But the thermostat is def. sticking, Takes 15 min. to get up to 190 degrees.
I'm just dreading working on it in this cold azz weather.
Old Dec 17, 2010 | 04:17 PM
THE BATMAN's Avatar
Bart did you get a new cell number, It's not working ? Call me .
Old Dec 18, 2010 | 06:56 AM
1Panel2NV's Avatar
Change those right now.
Old Dec 18, 2010 | 11:41 AM
bartSS's Avatar
Yeah change them. And Chris im sending you a message with my new number since yours got erased too
Old Dec 18, 2010 | 02:35 PM
Jaxon's Avatar
My stock plugs were fine to about 38k, around that time they had a slight midload misfire but no misfires under high loads or anything. Not enough to throw a code though. I have NGK 3787s in it right now gapped at .030 and no issues for a few K. The stocks are the best and for higher boost gap them down a bit. 032-030 is probally the best for around 24psi. I wish the stock clutch could hold more boost lol. It was holding 25.5psi but I could tell it was giving a little bit so I backed it down to conserve the clutch.
Old Dec 18, 2010 | 03:56 PM
THE BATMAN's Avatar
Guess what i'm doing in the morning. And it's gonna be a whole 23 degrees outside.
Can't wait.
Old Dec 18, 2010 | 06:31 PM
bartSS's Avatar
Those 3787s dont last long at all man. I barely did 8k on them
