timing chain rattle again
Old Mar 10, 2016 | 01:03 PM
himwestr's Avatar
Yes I have used the search button but cant find any info, bought a used 2011 hhr with 2.2l that had rattle at start up. Done some reading on forum about timing chain tensioner replacement, so I replaced tensioner but still had rattle. Next step I took was replacing timing chain and balance chain with all new accessories, no rattle for about a month. The bad news is the rattle has returned but I cant find out why. Any input would be great.
Thanks
Old Mar 10, 2016 | 01:35 PM
Welcome to the site, you mention accessories, do you mean chain guides and sprockets?
Just to confirm did you use the new style tensioner and did it engage itself or did you need to activate it?
Old Mar 10, 2016 | 01:54 PM
himwestr's Avatar
Yes new guides, sprockets and new style tensioner activated. Both kit where cloye brand.
Old Mar 10, 2016 | 02:06 PM
bluwing's Avatar
Hi,
Maybe one of the guides either broke or is loose.. It can happen even with new parts...
Old Mar 10, 2016 | 02:12 PM
himwestr's Avatar
Does not rattle all the time just once in a while at start up. Thinking about pulling valve cover off this weekend and taking a look. Might even try a another new tensioner.
Old Mar 10, 2016 | 02:29 PM
My suggestion as you suggest, open it up and take a visual!
Old Mar 10, 2016 | 05:10 PM
What about the balance chain tensioner?
Old Mar 10, 2016 | 05:19 PM
himwestr's Avatar
Yes replaced balance chain tensioner, chain, and guides.
Old Mar 10, 2016 | 06:39 PM
Silverfox's Avatar
Have you checked out TSB PIP4716A ??
Cam Phasers not parking properly. Pulley alignment and/or Serpentine belt replacement.
SF
Old Mar 10, 2016 | 07:02 PM
himwestr's Avatar
SF
Replaced s-belt when changing timing chain, alignment looks fine. How do you check cam phasers?
