timing chain rattle again
Old Mar 10, 2016 | 07:07 PM
Silverfox's Avatar
Google the TSB # for guidance.
Do a new search on HHR.net on this subject. I know I have seen several threads on the subject here.
Old Mar 10, 2016 | 07:30 PM
I don't think it is your problem.
#PIP4716B: Sharp Engine Rattle Noise At Start Up May Also Set P0011 - (Jun 22, 2011)
Subject: Sharp Engine Rattle Noise At Start Up May Also Set P0011
Models: 2011 Buick Regal
2010-2011 Buick LaCrosse
2009-2010 Chevrolet Cobalt
2010-2011 Chevrolet Equinox
2009-2011 Chevrolet HHR
2009-2011 Chevrolet Malibu
2010-2011 GMC Terrain
2009-2010 Pontiac G5
2009-2010 Pontiac G6
2009-2010 Pontiac Solstice
2009-2010 Saturn Aura
2009-2010 Saturn Sky
2009-2010 Saturn Vue
Equipped with the following engines
2009-2010 2.0L (RPO LNF)
2009-2011 2.2L (RPO LAP/LE8)
2009-2011 2.4L (RPO LE5/LE9/LAT/LAF)
This PI was superseded to update condition/concern with P0011. Please discard PIP4716A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
In rare instances a technician may comment they hear a short, sharp rattle noise from the front of the engine at start up, typically hot restarts. P0011 may also set during this condition
Recommendation/Instructions:
If the noise is from the front accessory drive area, inspect the engine belt. W e have seen concerns with engine belts causing a loud ticking type noise. If found, verify power steering pulley outer edge is aligned flush with shaft and repair as needed. If pulley alignment is correct and engine drive belt has been verified as the noise source, replace the belt.
If the noise is not from the drive belt and is very short and sharp in duration (2-5 seconds). This may be an issue with the cam phasers not parking properly. Remove the CMP actuator solenoids to inspect for debris. If debris is found, clean and inspect for torn or loose screens and replace if necessary.
If debris is found in the solenoids, P0014 may also set. Change the oil and filter before returning to service, in some instances it may be necessary to change the oil/filter multiple times with a test drive in between each. The oil filter and solenoids can be inspected afterwards to ensure no additional debris is present. If debris build up continues, further diagnosis/inspection of the cause may be necessary.
If the rattle noise has not been corrected after performing the procedures listed above, the concern is currently under investigation. This PI will be updated when further information becomes available.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information
Old Mar 10, 2016 | 07:53 PM
himwestr's Avatar
No check engine light, so I guess my phasers are OK.
Old Mar 10, 2016 | 08:47 PM
I guess you didn't read the FIRST sentence after the header.
"This PI was superseded to update condition/concern with P0011. Please discard PIP4716A."
The a rendition included a CEL. This one revises that. It says CEL MIGHT set.
Old Mar 10, 2016 | 09:35 PM
himwestr's Avatar
i guess i will pull the actuator out to see if there is any debris.
Old Mar 12, 2016 | 06:02 PM
himwestr's Avatar
Took valve cover off, every thing looks in place and chain is tight. Removed both actuators and nether had any debris. Is there anything else i need to check. We drove car yesterday about 150 miles with about 10 start ups no rattle, drove today 20 miles shopped for about 45 minutes and had sharp rattle start up. This car is driving me nuts. Any pointers would be welcome.
Old Mar 12, 2016 | 06:14 PM
I'd change out the solenoids, both of them.
Old Mar 12, 2016 | 07:16 PM
himwestr's Avatar
Are the solenoids common for going bad and causing a rattle at start up?
Old Mar 12, 2016 | 07:54 PM
You mean to say you replaced everything except the solenoids?
Not necessarily known for causing rattle, but known for going bad.
Have you checked spots out with a stethoscope?
Old Mar 12, 2016 | 08:22 PM
himwestr's Avatar
Have not checked with stethoscope, only rattle every 20 or 30 starts so its hard to catch it when it does it.
