Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I'm getting a service pressure sensor error message. On my corvette, it usually means I have to reprogram the system. Is there anything like that on the H2R?
Batteries in the tire sensors only last 8-10 years at the most. When was the last time the sensors where replaced ?
This is correct. You've got at least one bad sensor. Depending upon what is being reported for the other 2 positions, you may want to just replace all 4.
