Tire psi sensors
Old Jun 21, 2011 | 09:20 PM
Lucky's Avatar
Tire psi sensors
Has anyone had a tire psi sensor read 0 psi when the tire is not flat. I have seen post where the tire sensor will read --- but I haven't seen anyone say anything about just 0 psi. its just happens on my left rear tire and is intermittent I have checked the battery life of the sensor with a tire pressure scan tool and battery reads ok I'm guessing that its time to replace the sensor.
Old Jun 22, 2011 | 06:44 AM
solman98's Avatar
Sounds like a bad sensor. But these days, who knows........
Old Jun 22, 2011 | 09:04 AM
ChevyMgr's Avatar
The tool that dealers use has a function that will "wake up" the sensor. This may be all it needs. If that doesn't work then a sensor is needed.
Old Jun 23, 2011 | 08:47 PM
Lucky's Avatar
Update
Replaced the Lt. rear sensor today with a used one that I here. It has the latest part number stamped on it. I did a relearn and all is better. I did find that it is not all that easy to replace the sensor without completely removing the tire from the rim. I was able replace it just by braking down one side of the but its a tight fit. Next time I will think I will let the tire dealer install them but I was just too cheap this time and I just dont like other people working on my cars.
Old Jun 24, 2011 | 08:53 AM
timehhr2's Avatar
I just had a brand new set of American Racing wheels, Goodyear tires and 4 new TPM's installed. System seemed to acknowledge the change virtually instantly - showing all 4 with the 1PSI increase recommended by tire shop. It will be interesting to see what it does when I put the "old" (42 miles from Factory) wheels, tires and original sensors back on in the fall. Hope it goes as well.
cameraguy1
Tires & Wheels
Mar 20, 2015 10:43 AM
HHRcheater
Tires & Wheels
32
Jan 6, 2010 03:10 PM
1Panel2NV
Tires & Wheels
22
Oct 10, 2007 06:47 PM
